dude u got issues, do i know you or were just bullied as a child, cos u got something against me man an i dunno wtf ur prob is mate.
didnt your mummy ever tell u if u dont got nuthing nice to say...dont say nuthing at all??
cuz ur a twat and ur tryin to put someone down who is just doin wat he likes. maybe touching kids is more to ur likin since u seem to b an old ****.
hm he asked for opinions on here asking it is was "cool" or not. it sounds like he is doing what everyone else likes to me.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
