Do u have any Silver Greddy turbo timer + english manual = $129.00 + free delivery left?
If so i'm interested..
Also is it only a turbo timer or can it read boost and stuff aswell?
Pm me details Please..
Cheers..Let me know..
Some of the timer features... i reckon they are the best timer that is available on the market
It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
Able to automatically calculate and suggest the cool down time.
Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
PM SEND
  • 1 month later...
I AM BACK! Still available turbo timer and catch- tanks
Profec B will come soon!
Greddy turbo timer + english manual = $129.00 + free delivery (Available in Black or silver)
Greddy oil catch can + inc brackets = $159.95 + free delivery (15mm hose)
Greddy Profec B specII + english manual = $XXX.00 + free delivery (Available in black or silver) (SOLD OUT)
- Limited time offer and availability.
- No risk of getting caught by custom.
- Tax invoice will be provided. (I have ABN)
- Support the local industry.
*** WILL TRY MY BEST TO MATCH ANY PRICE AS LONG AS IT IS A GENUINE QUOTE ***
It is compact in size measuring 8cm x 8cm and 2cm in height.
Comes in new casing model with internal flashing LED pattern.
Speed warning mode
Speed warning mode
Greddy profec B spec II available now in silver and black.
479.00 + English manual + Free delivery.
Guaranteed genuine product! Beware of imitations!
Item is in australia, no more worries about taxes and getting caught by custom!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
