this hitman sounds like the sort of guy you can trust with your engine, as I have always been worried about guys that lean toooooo much! great figures on the day, but engine life is reduced a lot! as they say fuel never hurt an engine!
so $300 for Hitman, and is the dyno or road seen as the go? price difference?
the $300 for hitman is for a road tune - he charges extra for a dyno tune ($80 / hr upwards i beleive). Couldn't tell you whats better - anyone? But with a road tune there's the obvious risk of getting caught speeding (license loosing speeds i might add!!!), compared against the extra cost for a dyno tune, its up to you...
took him 30 mins to fit the powerFC and plug in his laptop, a proper boost gauge (i only have the factory one) and about another hour or so on the road tuning. Couldn't tell you how it compares to a dyno - although i'd guess they'd go through the identical process just, on a dyno and not on the road. He did a touch for me a couple of weeks later and that was also on the road
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
