Hey All! Ive just ordered a Tein Super Street kit for my 34 (if theyre no good its too late now anyways!! hehe) - has anyone used these before? I heard theyre ok for our roads cause they can be adjusted to be quite soft but also give a good feel on the hard setting?
also with adjustables is it a given that the lower you go with them the harder they should be set?
https://www.sau.com.au/forums/topic/62177-tein-super-street-comments/
I got some for my r33 gtst last week and I havn't found the ride to hard at all, you definetely feel the bump more and have to slow down on bad road but not uncomfortable. The handling improvement from the standard gtst is like a different car and adjusting shocks makes a large difference for body role. As you lower the car you actually losen the springs, so they are actually softer for lower and harder when the car is higher.
They feel great to me, though I haven't had much to compare against. I have never used adjustable suspension before, but I found that it can make a huge difference on the track. Was understeering terribly on the track, a few turns of the damper and the understeer was almost gone.
The ride is actually better (not as hard) as my old stuffed shocks and lowered springs. So was a huge improvement everywhere in my R33.
Sydneykid: Pretty much all the information is available here:
http://www.tein.co.jp/ssdamp2ne.html
And just because I am nice, I worked out all the conversions (there may be an easier way!!). According to the booklet I received with the suspension they are 4kgf/mm front and rear.
From the references:
1kgf/mm = 9.80665N/mm
Therefore:
4kgf/mm = 39.22660N/mm
1N/mm = 5.714 lbf/in
Therefore:
39.22660N/mm = 224.1407lbf/in
Therefore the answer is 224lb springs front and rear.
References:
http://wwwrsphysse.anu.edu.au/~amh110/Tech...e_conversio.htm
http://www.tomei-p.co.jp/_2003web-catalogu..._reference.html
PS: Thanks for all the excellent posts Sydneykid, when I see your posts I stop and read them from start to finish. ;)
I do it this way.....4kg/mm X 25.4 (mm's in an inch) X 2.2 (lbs in a kg) = 224 lbs per inch.
Which is OK for the front, but still too high for the rear. I would guess that they are still trying to compensate for the low rear anti roll by running a higher than necessary (to hold the car up) rear spring rate. A stabiliser bar upgrade is a technically superior solution. In the real world that means it won't compromise the ride comfort as much and allow much better (less wheelspin, more traction) launches.
:D
Well your way made a lot more sense! Glad I still came up the correct answer though :D
I really like this suspension, its hard but not too hard even for my 100km/h country roads. Compared to with my previous stuffed stocks with lowered springs its pure bliss, I don't have much else to compare too I'm afraid. :)
I had the front and rear set at 2 points (12 point adjustable from memory) from the softest setting. The rear was also set way too low (probably 30cm centre to guard). I found that in a straight line under acceleration you could feel the rear compress significantly and it was very difficult to get any wheel spin at all (i have allow subframe bushes too) - probably pretty good for the drags but not so great round the corners.
I've since changed the rear to about the 5th or 6th point (in the middle - probably too hard this time!) and the the front to the 4th setting. I've also adjusted the height according to the spec sheet ~ 33.5-34cm centre to guard front & rearl. Very much looking forward to testing this out at the next track day... once I've replaced the turbo :D
I'm looking at getting some upgraded front and rear sway/stabiliser bars from whiteline - would this be the next logical progression or would I be better off to get some more caster in the front?
From memory the spec sheet said 33.5cm centre wheel to guard. From the posts I've read (mostly Sydneykids!), the reccommendation is 34 - 35cm.
http://www.skylinesaustralia.com/forums/sh...center+to+guard
Also checkout these:
http://www.whiteline.com.au/articles/HPI_1..._Skyline01a.htm
http://www.whiteline.com.au/docs/Fact_Shee...line_R33GTS.PDF
Hope that helps :P
Sorry Reedy, but I need to kill this quickly............
A 200 lbs per inch linear rate spring takes 200 lbs to move it one inch, or if you prefer....
A 3.5kg/mm spring takes 3.5 kgs to move it one mm.
It doesn't matter whether that is the first inch (mm) or the 10th inch (mm) it still takes 200 lbs (3.5kgs) to move it one inch (one mm).
The amount of preload is determined by the weight of the car. If that corner of the car weighs 400 lbs (182 kgs) then the spring will need to compress 2 inches (51mm) to hold it up. But it still takes 200 lbs (3.5kgs) to move it the next inch (25.4mm).
Progressive spring rates USUALLY compress all of the softer rate just in holding the car up. ie; they are progressive to make sure the spring doesn't go loose at full droop. They are not progessive to make the ride softer initially. This is not ALL progressive sapring just Most of them.
Hope that makes sense :P
I just received one of them!!!! (yay!) - gotta wait for the rest now.. :cheers:
Did any of you guys sets come pre-set with what at least Tein would say is the best settings for the car?? I was reading something on the internet and it sounded like it says they are already pre-set?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
