Wanting to replace the clutch in a Skyline GTR 4WD 4WS, can I just remove rear wheel steering hydraulic line from the gearbox without bleeding or refilling oil system?  Does anyone have any ideas, or suggestions where I may find this out?
The ATTESA system will have to be bled once you disconnect the line. Not difficult to do, a bit like bleeding brakes. The procedures detailed in the WS manual - best get hold of a copy if you don't have it already. To minimise fluid loss and the amount of bleeding required try stopping off the end of the line once you disconnect it.
Thanks for that. I really appreciate your reply, that helps.
