Found this on another site and thought it would come in handy for anyone with an auto.
Apparently this works on R32's, R33's, maybe R34's and it also worked on my Stagea.
I have found a diagnostic routine for the auto box on another Nissan site. Most of the diagnostic routines are very similar even though the cars are different models.
So, here it is.
1. Have the car at normal temperature in Park with the overdrive on
2. Start the engine - the power light will go out after 2 seconds
3. Turn the ignition off
4. Move the selector to Drive (you may have to use the push button release)
5. Overdrive off
6. Wait 2 seconds, and turn the ignition on
7. Wait 2 seconds and move the selector to 2
8. Overdrive on
9. Move the selector to 1
10. Overdrive Off
11. Press the accelerator fully and release
12. Hopefully the power light will flash out a series of 10 or 11 flashes.
Here are the auto trans codes.
The sequence starts with one long flash. If everything is OK, this will be followed by ten short flashes.
Errors are indicated by a long flash in the sequence of short flashes.
1st flash longer: revolution sensor shorted or disconected
2nd flash longer: speed sensor shorted or disconected
3rd flash longer: throttle sensor shorted or disconected
4th flash longer: shift solenoid A shorted or disconected
5th flash longer: shift solenoid B shorted or disconected
6th flash longer: overrun clutch solenoid shorted or disconected
7th flash longer: lockup solenoid shorted or disconected
8th flash longer: fluid temperature sensor is disconected or the control unit power source is damaged
9th flash longer: engine revolution sensor shorted or disconected
10th flash longer: line pressure solenoid shorted or disconected
All flashes the same with no long start flash: battery voltage low, has been recently disconected or control unit has just been reconected.
Also found these codes, but I'm not sure if they are relevant;
Auto Diagnostics
Code Description
111 Inhibitor Switch
112 Vhcl Speed Sen A/T
113 A/T 1st Signal
114 A/T 2nd Signal
115 A/T 3rd Signal
116 A/T 4th Signal
118 Shift Solenoid/V A
121 Shift Solenoid/V B
123 Overrun Clutch S/V
124 Tor Conv Clutch Sv
125 Line Pressure S/V
126 Thrtl Posi Sen A/T
127 Engine Speed Sig
128 Fluid Temp Sensor
One thing I did notice is that you have to make sure the car (and gearbox) is up to running temps. Remember that the oil may take a longer drive to get up to temp compared to your water temp.
J
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
