Not sure what kind of knowledge you have with cars/tuning, but if you don't know much about these cars it may be worth getting someone else who does know them to tune it, but if you are from where your location says then, good luck :D
Not sure what kind of knowledge you have with cars/tuning, but if you don't know much about these cars it may be worth getting someone else who does know them to tune it, but if you are from where your location says then, good luck :rofl:
Yes, I am from trinidad and I am not too familar with this car and engine, I've tuned a couple WRXs and I work more on the Dragster's here. I do the electrical, computer and nitrous systems on the Rails. http://www.partytimeracing.20megsfree.com and http://www.mintcars.20megsfree.com.
I need information like the stock timing, if the car has a MAP sensor, the max boost on the stock engine etc. I already did some tuning on the car but I think I have not been able to get the full potential of the engine as yet.
the car has 2 airflow meters from factory,it has a map sensor but its for the gauge only and has no effect on the ecu.....the factory base timing is 15-20 degree's with the bac valve and tps disconnected....as for the link ecu,throw the thing up in the air and run as far away from it as possible before gravity brings it back to earth
There are no mods on the car as yet. The owner was told that the link would be able to faciliate upgrades later-on when he did any modifications. I'm stuck with it right now. I will have to do the best I can with it. It is twin turbo (stock), only 14 psi each (I think). What is the "bac valve"?. Where can I download a manual for this car (in english)?. I may be able to split the MAP sensor and send a signal to the link since it uses TPS and MAP for control. Do you think its better to run the car on TPS control alone?.
...why do you want to fit that useless peice of crap to the car?....
The owner of the car already had it installed in the car. He was duped into buying it. The original installer could not get the car working good, so they brought the car by me. I work on his Dragster so he thinks I can do a better job than the installer. I did manage to get his Idle down and the surging also the trottle response. I still have the boost problem where I need to retard for the boost and map fuel for higher speeds. The car is running rich at the moment but I had to leave it like that because the installer had the link set up for max boost and not incremental. I will have to find out what the installer did and get back to you. I know for a fact that the car is not firing sequential since they set it up for group injector firing, this I also have to fix. Do you have an e-mail address I can write to.
ylwgtr2 knows his stuff so whatever he tells you i'd believe :D
If its a stock RB26, stock turbos, 14psi is on the safe side... if you want a push a little more a lot of people run 1 - 1.1bar on stock turbos... power with stock turbos and stock fuel system will probably net you around 250-280rwkw
throw it out and tell him to put the stocker back in?
or maybe just buy a power FC mate
mark
I contacted one of the tuners at LINK and he told me that they have got 295+HP from the stock R34GTR (at the wheels, without any mods) and with additional mods it can only go up. Then again, I am from Trinidad in the West Indies so I have to take what they say.
as I progress with the tune I will let you guys know. One thing, you can really get addicted to driving the R34GTR.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
