Nice score Flight! Choosing colours for resprays is awesome fun..
BlueR32GTR: was that yours i saw in Leederville on newcastle St?  Recaro seats...gauges on passenger dash etc? scratch along the bonnet
Yep thats mine. Getting some work done at a mates garage before registering it. Some TLC and it'll be sweet.
I guess this is a spotted entry now hey!!
Hey flite nice finally arrived
what colours the spray going to be or just touch up?
did u used to own a modded r33 gtst,if so i think my brother stephen knows u.
yeah i had a white slightly modded gtst, umm i know 2 stephens, one thats a paramedic and the other that works with me and also owns a gtst
1989 R32 GTR
Blitz boost controller and turbo timer
Boost Guage
Nismo Dash
HKS Coilovers each corner
Twin plate clutch dunno wat brand though
Sent $7800 to japan for the car
$3700 to import broker for freight, customs and all that
$291 for compliancing
now just gotta license it, insure and respray
Flite, good price and very cheap..why?
My suggestion is before you spend all your money on painting etc, make sure the mechanicals are sound and you have fresh fluids, filters, belt, pump etc. That is do a major service on it.
Also get the compression test/cylinder leakage done to assess engine condition.
you may be in for a surprise, you may not.
Cheers
Ken
Cheers
Ken
yeah ken first thing i did was change all the fluids and stuff. Once the paint is done i was looking to rebuild the engine anyway, i was down at hyperdrive yesterday to get a quote on that, the dude said he'ld call me when he had the quote ready. Also its in better condition than I thought it was gonna be in. In the pics i got the interior looks all stuffed up and the body looked much rougher than it is.
Sweet car has passed the pits, I'ld like to thank my brother who works down there for getting it over for me :)
rofl..
Long, will get that price to you asap. I assume you know who will be building it here??
Cheers
Ken
rofl..
Cheers
Ken
um no i dont? i know you have new workers there, but even if you mention their names i dont know who they would be, i havent met anyone :)
and how much is that compression test?
Long, Anthony Scali ( nd4spd) will probably be doing the rebuild on it as our resident engine building/head porting/wolf tuning guru.
I think if you ask anyone on here , they will tell you what his achievements are.
Compression/cylinder leakdown test on the GTR is $150.
Cheers
Ken
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
