2 R32 GTR wheels in excellent condition with 245/50R16 Nitto 555R Drag extreme tyres (would probably only have enough left in them for a few of meets)
$600 ono
3 Pivot white faced gauges oil temp, oil pressure and water temp new in boxs
$650
I can email pics if needed
located in Sydney
Brett
  • 4 weeks later...
Do you still have the wheels/tyres for sale? Will they fit an R33 GTS25T? If so, I'm interested - please let me know (I sent you a PM - not sure if you got it as I didn't get a response).
Thanks
Sorry guys the nittos are sold, the R32 GTR wheels are still forsale
I also have 2 brand new ... never on a rim new BF Goodrich 255/50/16 Drag Radials that I would sell for $800
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
