Well I finally got the 32 registered.. nice drive (seems to handle better stock than my old modded R33). Could do with some more power, but plenty of time for that soon :wassup:
My main problem at the moment is that the auto trannie is pretty buggered. Seems to slip out at the 'fun revs'. There appears to be enough fluid in there, and it's fairly clear, so that is out the window. I might change it so I at least know what is in it I guess at some point. .
I know on some of the earlier boxes (i.e. aussie R31) you can actually tighten up the belts by tightening a few external bolts on the box. Is this possible on the later skyline boxes?
Any other solutions?
Just want to tighten things up a bit if it's at all possible, before tossing the slushy in a couple of months..
https://www.sau.com.au/forums/topic/65389-born-slippy/
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
    • Hi Cody, If you are looking for a simple "bolt in bolt out" solution, I may be able to help via trade. I'm swapping my auto RS4V from stock subframe to a reinforced S14 Rear subframe specifically for track duty. I was looking into different rear core options while the car was in air and I found your thread.   My VLSD rear is freshly changed fluid/inspected. I will say even with Redline diff fluid it is still not as aggressive as I would like with the "sports" viscous core, and coming from a heavily modded evo with full drivetrain I'm looking for a bit more rotation with the throttle.  I second this, the polyurethane bushings are pretty aggressive as is.  If you're interested in the trade, I am driving out to Chicago in September for a time attack event. I could swing by and make the trade somewhere Sept 12-13th or 15-16th if you are interested and you have not already solved this issue yourself.
    • No, the panel filter is the standard dry one. Yes, I did clean the AFM with electrical contact cleaner.
