Retrim R33 (part of door trim) Control panel with the power window controls etc
Ok. Does anyone know a good one in Sydney or tell me if they have done it themselves.
The control panel on the drivers side with the power window etc has the top layer peeling off. ANyone know a good product to use or a retrimmer and possible cost?
Many Thanks
PS its a 4 door so these parts are slightly different - i.e. couldnt just get another
anyone painted this part themselves to make it look stock and newish>?
hey,
when i bought my na r33 some d*ck had painted these parts white as well as half the centre console, vents etc.
i ended up spending ages gettin the crap off then just got them sprayed up in matt black. didn't come up too bad, just make sure the preparation is spot on.
Yes I've painted mine. When I got my car, the panel was overly shiney and looked like crap. Lived with it for ages until I decided to paint it.
Picked up a product from Supercheap. Can't remember the name (can find out if you really need to), but it's a pigment dye used for plastic and carpet. Gave the panel a good clean with metho, sanded it lightly with wet and dry to take out any minor scatching and hit it with about 3-4 coats of this paint/dye. Used the satin black. Looks absolutely brand new. The dye doesn't come off (rub off) at all. It was so good, I repainted the wing mirrors on my daughters car. They are black plastic which had oxidised and gone a greyish whitein some areas. Same deal as the door trim - came up looking like new.
The satin comes up with the same sort of luster as new plastic. Comes in a heap of colours too.
thanks guys. I have some dye at home in a spray can, but I didnt think that would work on the plastic..ie.e it wouldnt sink in. I thought you really needed something special.
Thanks for the feedback. I might have to go to supercheap and see if I can find the prouct :)
i resprayed most internal removable plastics gold including elec window surround/arm rest
but now im goint to have it all redone in mahogony it will look cool
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
