has anyone got some late model tail lights they wanna sell? or trade for old + cashish?
i realised that the old ones don't look as good as the new ones, the way they point downwards makes the back look like it sits lower too
https://www.sau.com.au/forums/topic/67265-late-model-tail-lights/
yeah you do, i was driving next to you two nights ago on the freeway, i was inspired, i want them because they look more "japanese" which is the look im going for, the early model tail lights look a little too american, plus the way the indicators point upwards makes the back look higher than it really is, it's an optical thing, if you look at your cars you'll know what im talking about,
if some of you wanna see some wicked job to be done on the early model, you paint the red bits black, but paint the centre garnish bit to colour code to your car! it sounds insane i'll hook up a link with someone who's done it in a sec,
i have the dark tint on my front indiaction clusters and side lamps, it looks fully! and yes because it's only a tint the light still shines thru perfectly during day and night, although it IS illegal, they still work fine,
and if you get defected you just wash off wish i a bit of turps!
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
