Not the average Bluebird!!! All wheel drive, 2.0 Turbo (SR20DET) 5 speed (factory)MANUAL.
Selling due to family constraints. This is a great car and is well looked after. The car is serviced every 5,000km with Mobil 1. I live in Melbourne & work in Geelong so the car mainly does freeway miles. The car is stock standard, but would be a great platform for those wanting the ultimate sleeper. I also have some extra MOMO wheels that can be added as part of the sale. Give me a call 0418 507030 or send me an email [email protected]
/ above is copied from the add on carsales.com.au
Additional Info:
We have a price tag of $15,000 neg and the car is coming up to 123,000km's.
I have attached a few photos. There are a few spots that need to be touched up such as surface scratches, faded paint on the spoiler and the mirrors and chipped ends on 2 door handles. See photos Bluebird 010,013 & 015. These are all minor and would only cost about $200 odd dollars to fix. Depending on the deal I am happy to wear this cost.
Call if you have any questions.
Cheers
Sean
Link to carsales
http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
