I have for sale 1 Panasonic X70, in excellent condition, only a few scratches. works perfectly, selling as I need the cash.
Brilliant little phone with a 64k colour screen and camera with a flash it comes with:
Charger
Instruction Book
Original CD containing software for the phone
$280ono
Here are a few pics with the phone and a link to the panasonic web site:
http://panasonic.com.au/products/details.c...m?objectID=2067
