Brand NEW in OEM Packaging UNOPENED Valve Lifters for RB26DETT
SET of 24
Height of the base: 1mm、Small base circle diam:φ30
・Corresponding to the TOMEI camshaft of more than 10.25mm lift
・High strength by cold forging、lightweight model
 approximately 32g(STD 33g)
Hi Octane Price is $607.20
You can have them for $500 ono
https://www.sau.com.au/forums/topic/70726-fs-new-tomei-rb26dett-valve-lifters/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
