  • Replies 61
well after last weekend, I've decided that so I don't have to spend night after night annoying my neighbours with power tools (and then feeling guilty even if it isn't late) I'm going to be seeing someone this Saturday to get a quote to have them moulded and have a small run made up. So I won't go quoting yet in case my best guess is waaay off :Oops:
Will let you guys know as soon as I know. Thanks for your patience :)
I don't think I'm going to bother getting a run done of the stick on eyelids. If people want those, please let me know (drop me an email) and i'll make them up. If the demand for them increases (for the stickies) I'll look at getting a small run done ;)
Sorry guys,
I've been waiting to confirm all of the details before posting up :)
The moulding process takes 3 weeks once the originals are finished. I'm aiming to get the originals painted next week, so it'll be about 4 weeks (once the originals are painted) till we have ready made parts :(
Price per pair is $150 :) and that will be for the bolt-ons.
They will have 2 mounting points (one at the outside, and another inthe middle of the headlight), and to accomodate those who's cars might not be as straight as we'd hope - they'll have metal brackets which will bolt the eyelid to the car (these will be supplied obviously ;) ).
It's going to cost the same for me to get stick ons made so I don't think i'm going to spend too much time worrying about them. If anyone does want stick-on's for whatever reason, email me and we'll work something out. Doesn't seem like there's too much interest for them anyway.
So i guess it's time to start taking official orders :) Please send me an email if you have any q's or would like put an order through. Pic's of the finished product will be up once the first set have been made from the mould.
Please let me know if you want them painted. Painting will cost more obviously. If you want them painted please supply me with your paint code and I'll arrange a quote.
Michael
P.S. Please make sure you email me if you are definitely interested. This will help me work out numbers :)
Will have pics in about 4 weeks :D
:P
  • 3 weeks later...
Well lads...they'tre painted and off to be moulded this afternoon :O They look great, better than I thought they would. There were a few delays with the painters, but we got there in the end.
I'm still shopping around for a good price on the paint, so if you guys can recommend any painters please PM me :)
Not long to go now :(
:D
Michael
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
