If you want smooth power delivery and no boost problems then dont even think about using an internal gated turbo as big as a GT35
Its been done, GT35R internal gate with a .82 diesel exh. housing holds 19psi well. :cheers:
Obviously the exhaust housing isn't optimal for GT35R but it does work and appear to work fairly well.
It really comes down to the design and how big the internal gate is.
For example the HKS2855ProS (recently an RB25DET made 317rwkw on Tilbrooks dyno, big cams, plenum, big exhaust etc) & the 3037ProS. The internal gates are 45mm big.
Unfortunately home brand bodgy jobs is what scares people away from the internal gate.
https://www.sau.com.au/forums/topic/72642-gt3540r/page/2/#findComment-1343609
Im using the 35/40 on my RB30DET with a garret .82 internal wategate Truck housing, it works very well .Im now currently making 306rwkw on 20 psi, still uising the stock head, stock cams, and stock bottom end. Cant wait to get a decent set of cams and see what it does.
https://www.sau.com.au/forums/topic/72642-gt3540r/page/2/#findComment-1343638
    • Looking to do a turbo conversion on my RB25DE Neo Does RB25DE Neo lower intake work with RB25DET Neo Upper intake manifold?    I found an upper only intake manifold for sale but not sure if it will fit the bottom  half stock intake manifold I have already? Thanks  Also if your selling any parts relating to RB25DET Neo pls reply below or dm.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
