Hi guys,
I've just my car from Japan about 2 months ago, and unfortunately I can't keep it, as I need another operation on my shoulder.
Due to the public health System being as it is, I can't wait the time (at the moment its 2 years 1 month) minimum, So I'm going to hook in and pay cash.
Hence my Beloved Soarer must go.
Pictures will be available once I get my digital camera back :roll:
I'm looking for about $19k with everything, but I am very negotiable.
Call me with your offers
James - 0402 012 635
FULLY COMPLIANCED
FULLY ENGINEERED - ALL PARTS ARE ON THE ENGINEERS CERT.
NSW Rego until Mid Next year!!
Car pushed out 285kw at the rear wheels, and was running quite rich, its now had a very very good tune and will make over 300kw.
1989 Toyota Soarer modified
2.5L turbo
5 speed manual
cream / gold
1JZ-GTE engine conversion performed by D-West in Japan (http://www.dwest-web.com)
HKS make 1. 2 millimeter head gasket
Trust T-78-33d turboTurbo recently reconditioned (Under 1000km's ago)
External GREDDY Racing waste-gate Type C
custom manifold
Skyline GT-R Front mount intercooler
Custom intercooler piping
HKS cams
[*]264° Inlet
[*]272° Exhaust
HKS adjustable cam gears
550cc injectors
R33 GTR fuel pump
Aftermarket Fuel Pressure regulator
Blitz oil cooler
GREDDY Oil filter relocation kit
GREDDY Oil/air seperator (Catch can)
Adjustable front and rear suspension (Cusco front, Tien HA rear)
Aftermarket straight through exhaust
TRD LSD
Aftermarket ECU
OS Giken twin plate clutch
Sony CD Head-unit
Greddy E-01 Electronic boost controller
Boost and exhaust temp gauges on A-pillar
Water temp, oil pressure and oil temp gauges in glove box
All these guages are electric.
Additional boost gauge for passenger's observation
Sunroof (That actually works!! Unlike may other Early soarer's
I also have a heap of spares that will be included with the car, Including spare Nitto slicks, Spare blitz wheels, exhausts, brake lights etc LOTS of stuff but these will go with
the car.
I think thats everything...
**Edit**
Some images from the Auction Data sheet.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
