Im selling my 180SX due to financial reasons... Lost my job and can longer afford my loan repayments so shes got to go so i can repay my loan and credit card :)
Heres the info:
Nissan 180SX with an RB20DET Conversion.
72 XXX on the clock 4X XXX on motor when purchases as halfcut
5 speed Manual (gears are very tight and smooth)
Serviced every 5000ks with Fully synthetic oil.
4 good tyres
NSW registered
Totally immaculate inside and out.
OUTSIDE
-Complete respray in R34 GTR Bayside Blue with 2 coloured pearls and a metalic flip - Spray includes enginebay and door sills etc.
-Cwest front bar, vertex side skirts and rear bar
-Spoiler removed and holes filled
-Vented Fibre glass bonnet
-Electric Gandor Aero Mirros
-Clear side indicators and front indicators
-18" HP Design rims in Gunmetal (only about 3 weeks old)
-Very dark window tint
INSIDE
-Roof, Door Trims, Glovebox, retrimmed in Blue
-Monza Reclinable front seats (blue and black)
-Centre consol and guage surround sprayed in silver
-Custom febreglass centre consol with 3 Autometer guages - Boost, Oil pressure, Air/fuel
-Nardi Leather steering wheel
-Leather gear knob
-Chrome & black hand brake
-Autometer 5" Moster Tacho with blue shift light
-Relocated aircon/heater in custom setup in center arm rest with turbo timer as well.
-VDO CD Player
-Alpine 6X9s in the front doors
-Brant 6 Point keypad immobeliser and alarm, Under bonnet and incabin siren, motion sensors etc top of the range.
ENGINE
-RB20DET motor conversion
-RB20 gear box
-GTR 1.5way LSD
-RB20 Radiator with twin thermo fans
-Rebuilt Motor
-50thou over pistons o-ringed
-Copper head gasket
-Brass Button Clutch
-Custom Plenuim
-Custom Garrett GT28-40
-Turbosmart PROGATE 45 external wastegate with screemer pipe
-R32 GTR Injectors
-EMS stand alone computer
-DNA FMIC 600X300X75 with custom pipe work
-DNA Pod in custom alloy airbox
-DNA Boost controller
-Boche Fuel Pump
-Rising fuel pressure regulator with fuel pressure guage
-Surge tank
-Oil catch can with breather
-3" Turbo back zorst with screemer pipe off wastegate, Hi flow cat etc
-5Ziggen Muffler
-Aftermarket earthing kit
-Big boshe battery
-Nismo Oil Cap
BRAKES & SUSPENSION
-5 stud conversion with Skyline 4 spot calipers painted blue
-Tien front coilovers, Height & Dampner adjustable
-Tien adjustable camber tops
-Custom rear coilovers, Height adjustable
-Adjustable Castor/Radius rods
-Rear strut brace
-New Bendex brake pads
-Braided brake lines
THE CAR COMES WITH ENGINEER PAPERS FOR JUST ABOUT ALL MODIFICATIONS
Im sure there are more modifications which i have not remembered.
This car is very quick and handels like a go kart.
This car has nothing more to spend on it and is ready to take to the show or track.
Had $22000ono on the car but due to looseing my job i have lowered the price to $19500firm as rego is due JULY9th and i dont have the money to re-register it so im really wanting to sell it before then. I have no doubts the car would pass rego with out hassels... The only thing which i think would be picked on would be the window tint being dark but this is an easy fix. Other then that everything is engineered and would pass easily :rofl:
Im looseing lots of money but what can you do when your in this sort of situation :rofl:
Call Troy on 0402 756 302 .... or email [email protected]
could consider swap with WRX or Skyline just have to see pictures etc...
Im going to just go give it a wash and take some pics now so ill post them up later.
Cheers
hey mate....
Are you the guy who has been sending my MMS but they havent been comeing through?
I can put my sim in my old phone and get you to send them again and try again...
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
    • Who tuned it? Have you spoken to them about the hot start issue yet?
    • injectors were upgraded (1000cc), stock turbo high flowed, return flow infercooler and ecu nistuned before tuned
    • Injectors? Note, there is no way that I would run E85 on stock injectors. They are too small.
