hey
i have done a search and found alot of good things being said about this turbo for the rb20.
I am looking at upgrading in the near future to possibly one of these...but the thing i havn't been able to find are where abouts i should start looking for one of these...rough prices new and second hand...and how much somewhere would rougly charge me to have this fitted to my car.
All help appreciated
I am in brisbane
thanx
https://www.sau.com.au/forums/topic/74396-hks-2530/
hey
I am in brisbane
thanx
These turbo's respond good, just make sure your exhaust housing isnt too big.
just buy the "HKS" bolt on for RB engine.
They will fit on with everything else untouched... sometimes even the standard ecu will run them "OK"
https://www.sau.com.au/forums/topic/74396-hks-2530/#findComment-1366224
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
