pitchd Posted May 31, 2005 Share Posted May 31, 2005 hey guys, i want to get aftermarket pulleys for my rb20... cannot find any - can only find rb25 and rb26 will either fit? - adz Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/ Share on other sites More sharing options...
yogi000 Posted May 31, 2005 Share Posted May 31, 2005 mine on the box that i have will suit rb26dett......that jun Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/#findComment-1383888 Share on other sites More sharing options...
pitchd Posted May 31, 2005 Author Share Posted May 31, 2005 so rb26? - adz Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/#findComment-1384047 Share on other sites More sharing options...
BHDave Posted May 31, 2005 Share Posted May 31, 2005 The crank pulley of the rb25 is thinner as is the power steering pulley on an rb25 as the power steering pulley only has 3 ridges on the belt instead of 4 like with rb20 as the rb20 has a big pig of a p/s pump due to the hydraulic hicas. I am running an rb25 with rb20 accessories atm. everything lines up, it's just a matter of replacing the belt for the P/s. If you can check that the p/s shaft of an rb20 pump is the same as an rb25 pump you could run the aftermarket rb25 setup. Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/#findComment-1384314 Share on other sites More sharing options...
yogi000 Posted June 1, 2005 Share Posted June 1, 2005 pitchd i'm pretty sure the rb26dett are the same....just ring a parts supplier and they'll confirm for u Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/#findComment-1385001 Share on other sites More sharing options...
pitchd Posted June 1, 2005 Author Share Posted June 1, 2005 im most probably going to be putting an rb25 PS pump in as my current one is a hicas RB20 pump but it has a bolt blocking the secondary hicas line... very dodge - upsets flow characteristics of the pump obviously i just wanna order some lightweight pulleys - wonderin whats gonna fit - adz Link to comment https://www.sau.com.au/forums/topic/75398-rb-pulleys/#findComment-1385077 Share on other sites More sharing options...
