Hey guys i want to sell my r31 skyline
i have had it for 4 years in june now and i must sell it to start on my new car
its a nissan skyline 1986 GXE 5 speed manual 206000 k's on the clock
it comes with:
- full custom body kit
- custom spoiler
- professionaly lowered suspension by pedders
- 17 inch wheels - 17*7's all round with 215/45/17 on all 4 corners - they have been powder coated white to suit the color of the car
- Stainless steel exhaust - 2 and a 1/4 inch straight through with tip on the end - beautiful deep sound
- set of extractors
- pod filter
- chipped ECU - got a chip in it for better performance - dont know how much though
- After market steering wheel
- Genuine Nismo gear knob
- interior is perfect with blue seats and door trims - no marks or holes on any of the seats
- its got a kenwood stereo - thats all i know about it with some six inch speakers in the back
- its got a stage 2 shift light which is situated above the steering column - goes from yellow which is first warning then to red whch simply means change NOW
- Then in has all the basics - air con, electric mirrors, power steering, alarm, immobilisar, central locking which works off the alarm,
i have spent heaps of money just making this thing reliable and good to look at. This year i have replaced the timming belt, air flow meter, ignition module and plenty more
i have receipts for heaps of services and it always had one after 10,000k's
The body kit is very very hard to get and i have been approached by many suppliers to get a mould made of the kit and to make copies to sell - i didnt want to because i wanted it to look unique so there is money to be made off the kit
i know im forgoting heaps but if you call me on 0402143495 i can ill you in on any details which i have forgot to mention - im located in melbourne - endeavour hills
im asking 7100.00 for the car which is negotiable - you wont be sorry with this car because all you have to do is buy it and not do anything to it - you dont have to waste money on doing all the basic things to it which i have already done
its actually in the australian drag racing magazine with my friends 10 sec r33 this months edition so if you see the mag have a look for my friends black 33
i dont use the net much so give us a call if you have any questions about the car
the number plates dont come with the car unfortunately but if you want to give me an offer i might consider it
it has rego till the end of july
i have some more pics of it if you want i can send to your email if you want - i dont know how many pics i can put up of it
thanks heaps guys
steven
https://www.sau.com.au/forums/topic/75466-nice-r31-needs-to-be-sold/
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
