Well in 30min im going to the mechanics to get them to check out my second gear synchro that is crunching and going on. It's an "inspection" to see if they will cover it under warranty or not....everyone wish me luck because if they don't I'm going to be less then impressed. :singer:
2fardown,
Good luck, but anything that has "wearable parts" ie clutch etc they usually try and squirm their way out.
Warranty group, bar none are a bunch of fu)king co)k smoking monkey raping lesbian crackhores. You are usually better off gambling you $300-600 at the casino's, then saving you winnings for a lucky day.
Personally I have been shafted every car I've own, with multiple warranties groups. They all try and say you've flogged the car, or you have taken it on a track etc. Thing is, if the cars ****ed up, it usually means that it was done BEFORE you got the car.
Oh well, I'm just bitter, but hopefully they will recognise you and get you box fixed.
Cheers,
Tim
Well after the mechanic and I took the car for a ten minute test drive he could feel something was a bit wrong...so he changed the oil for me then and their with some Shell stuff that has improved it heaps...he said to come back in January and he will inspect it again. If it hasn't improved much he will replace the synchros in 2nd & 3rd and also do the bearings under warranty! So I'm happy it's all going to be covered. :)
Yeah I asked the mechanic about the redline stuff and he said its good if your synchro is totally rooted but he also said that slippery lubes like that don't allow the synchro to bite onto the teeth of the gear properly or someshit. Anyways my troubles over. :)
Depending ont he warranty you have, it *should* be covered. I had a used car warranty on my R32, and the paperwork said "All internally lubricated parts", which includes synchros. No argument.
The synchro relies on friction between the synchro cones to speed up/slow down the gears in the gearbox. If they are worn, or you use too slippery a lube (teflon additives etc) it can effect the amount of "bite" you get in the synchro cones.
An old rallying trick is to cut radial grooves into synchro rings, to allow the oil to dissipate better (bit like tread on your tyres). Sounds rough, but apparently works a treat, and lets you make much faster gear changes (wouldn't recommend you try it on your Skyline tho)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
