Can anyone help because my RB25 is free boosting, when i accelerate hard the BLITZ SBC eltronic boost controller seems to bleep and go read as is gones over safe boost, This is not the solinoid as i have already replaced it. I need help as im scared of blowing the HKS25/30. My actuator pipe is on. Though im having problems with my coil packs but under my understanding im sure that does not effect my boost at all. Not sure what to do because the car does not perform when its free boosting.
https://www.sau.com.au/forums/topic/76454-overboostingfreeboosting/
well if your gain setting is up to high your car will over boost, its a 1-100 setting, mine is set at 12-15 im not sure if aftermarket turbos can be set higher but have a play try setting at 15 and see if it still does it, not sure if you also know that when changing the setting the controller will take 3 or 4 learning runs before it sets itself so you will need to do 3 runs up to high revs see if it makes a difference anyway. do you have a manual for it because i can post one up for you. is it the id3 that you have?
yes try 15 the higher you go the faster boost will come on, so if you had it on something like 60 its going to boost spike, so try 15 and do 3 runs as it will be in learn mode for a few runs and see if it makes a difference, im looking for the manual for you at the moment.
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
