I plan to go overseas this year and regretfully will be selling my car. It is immaculate condition and runs beautifully. I have spared no expense when servicing and upgrading, using only top shelf fluids, parts and accessories. I’m the first Australian owner of the car and have all import and compliance documentation.
I’m asking $18,500. I will be open to reasonable offers but please don’t waste my time with unrealistic ones. I believe this car is worth every penny of what I’m asking because I know what condition it’s in and how it has been treated.
1993 Nissan Skyline R33 GTS25t Type M
General Features:
• RB25DET engine (2.5L DOHC EFI Turbo with VVT).
• 5 speed manual.
• 135,000 genuine kms (don’t be sucked in by fraudulent km claims).
• Power steering, windows & mirrors.
• Factory electric sunroof.
• Climate control
• Pioneer CD player with JL Audio component speakers.
• 3 point immobilizer and alarm.
• HICAS 4 wheel steering.
• Nissan 100,000km Service.
• Fluids have been changed every 5000km with major service every 10-15000km.
• RWC with 12 months rego.
• 450-500km per tank of fuel.
Cosmetics:
• SKY-033 number plates.
• 7 spoke 18” Payton Place alloy wheels (manufactured by http://www.rayswheels.co.jp/indexe.html ]Ray's Engineering[/url] ) with Hankook Ventus K104 Sport tires (approx 20,000 km left) 235/40/18F 255/35/18R.
TEIN Type HR Damper suspension (height and damper adjustable) with progressive sping. The car has been lowered but is a legal height. Contrary to rumors these are very comfy on the street due to the progressive spring feature.
Custom paint: The car has been re-sprayed the factory black with a blue pearl through the clear coat. No other 33 has this exact colour. It ‘flips’ from black to navy blue depending on the angle and level of light.
• Tinted windows.
• Nismo gear knob.
• Leather gear stick and hand brake boots.
Modifications:
• Full (and legal) exhaust system from the turbo:
* CES Racing Systems split dump/front pipe
* Stainless 7.5L high flow cat (recommended for GTR's)
* Jasma 3” straight through cat back with tip
• Access (Blitz) chipped ECU.
• Bleed valve set at 13psi.
• K&N panel filter in factory air box.
• Heavy duty 5 button sprung centre clutch (only 1000km old). Pedal feels like stock.
• Diff cradles (pineapples) to enhance traction.
Performance:
• The car has made 195kW at the rear wheels on the SelectMaz dyno.
• It has previously run a 13.83@101mph quarter mile at Heathcote Raceway (when the car was making ~150rwkW). It now should comfortably run a sub 13.5 sec pass.
Comments and Compliments:
• Mag Wheel & Tyre Preston: “I can tell this car has been looked after, the under body is so clean and tidy” :uh-huh:
• Tint a Car Preston: “Have you had the interior re-upholstered?” lol… no :D
• Driver Dynamics: “How old is this car? It looks brand new in here.” :(
• General regular comments: “Love those plates”, “I love the colour”, “you’ve done just enough to the look without going over the top”, and my favorite “Is your car black or blue?” :D
Pics:
Its stock orificer :(
https://www.sau.com.au/forums/topic/76767-blue-r33-gts25t-type-m/
hey, i like the car. so its got the S2 engine? looking at getting a line in the next 2 or 3 weeks, probably (hopefully) 2, so il definetly be in touch if the car is still avail. i like how straight the body looks with that colour. well thats my 2 cents anyway if all goes to plan it will be my car by the end of the month :rofl: had the major service yeah all the belts etc? will negotiate a price with u when i am definate, but just so i dont put off other buyers, good luck with the sale. this is a fine example, if you have the cash before i do, get this car.
AGREED! that is a mint looking rig...
but... that dyno sheet is a bit dodgy looking... where is all the info? customer? I.D? Description? date? or did you blank it out?
good luck with sale
polka, yep, altho some guy is trying to organise a time to drop off a deposit. I've given him till Sunday then I'll stop taking him seriously.
Prospector, image has been blanked. I've got the original. There were about 20 other SAU members who witnessed it also :P
Prospector, image has been blanked. I've got the original. There were about 20 other SAU members who witnessed it also ;)
i can vouch as a witness to the 190rwkw that it made at selectmaz...
good luck with the sale ;)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
