Hi all,
I have searched and can't find a thread regarding wheel bearings.
My questions are:
After you take the disks off are the bearings then exposed / able to be removed?
Are these a sealed unit requiring the whole assembly to be changed I.E cradle and bearing?
Rough cost of wheels bearings for r32 GTR?
I previously havn't had hands on experience maintaining my car but would like to start doing so and this appears to be next on the list, so all help is much appreciated!
https://www.sau.com.au/forums/topic/77541-r32-gtr-wheel-bearings/
I remember browsing through a CBC catalogue and seeing GTR bearings listed. Most newer hubs have sealed bearings that can't be serviced. If the bearings noisy it wants replacing, if not then its fine. Plenty of front wheel drives with similar setup out there have done a zillion km's with out the bearings needing to be touched. Cant see why skyline ones are any different.
Only a bit of info here for you....
Cost.......Gary Rogers Nissan, nunawading (vic). $140 per Front set (2 off). Midas, $150 to install. (pretty cheap considering they're pricks of a things to remove!!)
They're big, flat, heavy, non-conical, one bearing per car side things!!!
This was for my R33 non GTR!
One of the rear bearings needs replacing in my car (has some play in it)... they are a completely sealed unit, and yes you have to replace the whole lot. Mechanic got the assembly for me, was over $100 but sub $200 to my knowledge. Its being changed this week, will let you know of any tips/tricks for getting it done.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
