New Stock Of Profec B Spec Ii And Turbo Timer (lots Of Function) Best Price! W/pics!!
NEW STOCK!!
BUY FROM A REPUTABLE TRADER IN THIS FORUM. YOU WONT BE DISAPPOINTED!!
CLICK HERE AND JUDGE FOR YOURSELF!!?
ALL PURCHASES COME WITH TAX INVOICE AND NO MORE TO PAY!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
- Paypal (3.5% surcharge)
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = SOLD OUT
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = SOLD OUT
* English Instruction manual will save you a lot of frustration. Trust me on this.
-Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI).
-There are optional warning and boost limiter functions that can be programmed to offer much more control.
-The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
-This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
TRUST AUTO TIMER
It is compact in size measuring 8cm x 8cm and 2cm in height.
Comes in new casing model with internal flashing LED pattern.
It has several mode to measure speed such as
Attack mode indicator - to record 0-200m, 0-400m, etc.
Attack mode indicator - to record 0-100km/h, 0-200km/h etc.
Stopwatch mode - to record up to 30 laps from 0 ~ 9'59''99
Best lap time mode - indicated by "BEST" being displayed.
Speed warning mode
Your current speed (with 'real time' speed reading)
Able to automatically calculate and suggest the cool down time.
Perform as all important battery mode indicator and to display 'real time' battery voltage. Crucial for those with sound systems.
Optional sound mode (i.e. to turn the sound ON or OFF).
Incorporated with parking brakes and speed safety features.
GALLERY
GREDDY AUTO TIMER
GREDDY PROFEC B SPEC II
  • Replies 57
hey man, does the turbo timer come with a plug made up so that it can just be plugged into the ignition line with mnor soldering?
yap it does come with a plug n you can minor soldering to connect it.
NEW STOCK!!
ABN 77 934 867 271
I accept:
- Direct Deposit
- Money Order
BRAND NEW TRUST PROFEC B SPEC II + ENGLISH INSTRUCTION* = $479 + FREE DELIVERY (AVAILABLE IN SILVER AND BLACK)
BRAND NEW TRUST FULL AUTO TIMER + ENGLISH INSTRUCTION* = $129 + FREE DELIVERY
TRUST AUTO TIMER
Speed warning mode
GALLERY
GREDDY AUTO TIMER
    • Yes you should be able to use that connector to force it to run, that is how you bleed the system. If it doesn't work for some reason it will also run if you have the engine running and open one of the bleed nipples (put a plastic tube on it first like when bleeding a brake nipple to make sure no air sneaks in). A common cause for error 51 is the earth between the subframe and chassis causing the pump to get insufficient power (because the subframe is rubber mounted)...you could start by just adding an earth if the factory one is suspect.
    • This arrived in the mail 馃い So I've paired it with a Tomei exhaust coming from Kudos too. Ended up getting the GTR one, fitments is hopefully not too far out.
    • I might have when I had my S15, but that would've been Pre-2012.. not anytime recently.. when I get this build on the road, will see hopefully there's some meets planned.
    • What a mission....good perseverance and thank god we don't really have a rust problem around here!
    • That is a right pain, but much better than having a dead forever unit, good on them for helping (sort of) instead of ignoring. Most likely internal connections will be like a laptop/consumer electronics. Tiny white plug/socket connectors, sets of pins joining mother/daughter boards and ribbon cables for any display connectors into those long plastic housing that flip up (I can see at least 2 of those in the pics). If you are not familiar with them, there would be youtube on all of them, nothing is hard just need to know the tricks
