Hey to all SAU members!
Im not a supplier however I have 10 Greddy Catch Cans for sale.
Once these are gone they are gone for good as I said, its a limited offer!!
Greddy Oil Catch Tank collects the oil and moisture in the blow-by gases that causes carbon and sludge build-up in the intake system and the engine. It keeps the engine clean even under hard driving conditions. It is also an excellent engine dress up item and gives it the race car look with the polished aluminum body with sight glass.
Super Light style mounts vertical only and has high capacity. Mounting brackets included.
These are BRAND NEW, comes with all fittings and hose required so fitting charges are very little (if you dont want to do it yourself).
Cans have GREDDY written down the side of them and are very polished.
I have included pics at the bottom.
Anyone wanting to order one can contact me through quickest on my email account, [email protected]
Price is $160 + FREE DELIVERY anywhere in Aus!
Edit: Few people asking comes with all mounting brackets, hoses and clamps included as well :)
https://www.sau.com.au/forums/topic/78237-greddy-catch-cans/
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
