We have decided to upgrade from the $99 one too a $400 one which I'm not too happy about but I seem to have no choice.
The one we are getting has a scanner in it too so that might come in handy. I just didn't wanna have the arial sticking off the roof and the radio sitting just anywhere in the car.
I think it makes it look untidy. But oh well :)
  • Replies 78
OR you could be like us and have TWO FOR SOME STUPID REASON!!
But we might have two cars soon.. so the scanner/uhf will stay in my car and the handheld in the mini :)
But also we could have it on the scanner while talking on the dicky smith special!!
Nismogirl, this may sound like a stupid question but am I to assume the scanner/uhf combo model you have allows you to listen to crap eg. Police, Emeregency, GRN, etc ?
If this is the case then this is the model I will get also as it will be good to have a scanner around for activities such as the Peats Ridge playground ....
I was thinking exactly the same thing....:confused:
It is.. But you can't listen the UHF and the scanner at the one time. Its basically got 60 channels. 40 for normal UHF and the other 20 are being programmed for police on sunny coast/gold coast/brisbane. Not sure about other emergency services though. Not that you really need to worry about ambulance and fire pulling you over and taking your car off you!!
The price that we have got ours for is $440 programmed. They are usually around $479 mark (RRP) but we are getting it cheaper through a friend of a friend (plus its gonna be programmed which costs $$ too) Its a GME TX4400 i think. Its a DIN size so it can still go in the dash.
http://www.gme.net.au/land/tx4400_main.html
There the info. Looks pretty swarve. AND to cater for my needs (cause i dont want a dirty big ugly arial sticking off the side of the car) we are gonna get a glass mount one like the coppers have. I think it will look better than off the roof or the front quarters.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
