I could be wrong but if you look and talk to most experince drifters that do it for al iving they will tell you the same thing.  You will find that not many of them would be running over 14psi.
I know lots of experinced drifters that run over 14psi. I run 19psi, but I'm not saying I'm experinced :P My shop's car runs 22psi. Most of the D1 cars are setup around 1.4+bar.
i cant see what it would matter what psi u r running if drifting, if you have a decent intercooler and keeping the temps down you wont have a problem. and for high rpm's in drift, just go to any drift comp and listen to the rev limiters, thats sounds like big rpm to me.
Most D1 cars run fully forged, fully built $25 or $30K engines.
Buy a turbo that flows the power you want within the peak of its efficiency - this is, and will always be the best way to match a turbo to your car.
Check here: http://www.driftaustralia.com.au/forum/top...sp?TOPIC_ID=233 for power info on trust turbos
A brilliant turbo for RB20 is hks 2530, at 1.2bar they absolutely rip, Wide power band, responsive - an excellent turbo for a drift car. At that boost you dont have to touch the internals, just keep the rev limit to 8000 rpm and it will love you. You do of course have to change fuel pump and up the rail pressure for it to be safe.
ok just so everyone knows, its not a stock engine, very far from it, has forgies and preped bottom end. thats all i will say as im not giving away any more info on the internals at this stage. it will have a rev limit of around 8200 - 8500. and yes has over kill supporting mods for the power.
OK, dont really see why that is relevant, but bottom line is the higher the boost, the more heat in the engine PERIOD, no matter how much you cool the intake temps 15psi will always have less heat than 20 psi - the piston compresses the charge air = heat.
To run higher boost, you need to drop the CR to reduce the amount of heat being generated in the cylinder. Lower CR means more sluggish off boost and longer to come on boost, cams means less cylinder efficiency at lower revs, which will bring boost on later too.
With an RB20, they dont really do much under 3000rpm stock, drop the CR further (for higher boost) and that will move right - throw in some cams and it moves further right again.
Forged pistons will retain less heat than standard, so you can run higher boost (heat being the issue). At 8.5cr with standard pistons, you are playing with fire above 1.2 bar for reliable, constant full boost thrashing. With forged pistons, you could probably run 1.3bar without dramas.
If you intend to run more than this, you should seriously thing about dropping the CR further - but getting boost in before 4000rpm may be a problem on a turbo the size of the td-06-20G.
My advice would be to build your engine at 8.5:1 and see what happens at 1.3bar - if you need more power, or want to tune at higher boost pressure, either be prepared to run a fuel ****tail to increase the ron, run elf fuel or decompress the engine further.
Remeber, if you think only of the top end power, you may well end up with a car that is only suitable for drag, ie, very narrow peaky power band. This not only will be very dissapointing, but could be more expensive to rectify than simply changing your headgasket to decompress the engine slightly, or using a higher ron fuel when thrashing.
my 0.02 - good luck, sounds like it will be a very nice package.
  • 4 weeks later...
Their boostd life is 30,000-40,000km's where as BB turbo's are generally up around the 70,000km mark.
If you are not leaning on the turbo hard it will last much longer. Pushed to their airflow limits this is roughly the life you should expect.
I'll do those rb20 airflow plot calcs when I get a little time.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
