  • Replies 75
I am after a complete R33 IRS LSD diff,  I am going to put it in a VL Commodore so I need the lot including brakes.  How does $500 sound for the lot.  I think $500 is pretty fair there doesnt seem to be a big market for these diffs and there are a lot for sale I can get one missing brakes and rotors for $450 but id rather get it complete.
Hope you dont think the offer is silly, but im not in a hurry and they come up fairly often.
Cheers Edward
brakes are all gone but u can have ur choice of diff, both from low km cars both great nick one came from a abs model the other a typical gts-t, $400 each....
also guys this new forum system sux! its saying my pm box is FULL at 100 msg's if ur serious and only serious bout parts i have email me at
[email protected]
if not just keep posting here
:O hating new forum setup...sorry but either email me of hit me here...grrrr
[email protected]
:rolleyes: hating new forum setup...sorry but either email me of hit me here...grrrr
Thanks man, im going to have to think about it, I may be better waiting around for one with brakes. Plus I am having trouble with my job atm. ;)
Thanks man, im going to have to think about it, I may be better waiting around for one with brakes. Plus I am having trouble with my job atm. :)
thats no drama at all i got a rb25det head with all the goodies to go on a rb30 block if ur after twin cam conversion to :)
to the rest of the forum i emptied some pm's and replied to some keep em coming
front n rear windscreen gone
have 1 rear windscreen left
and 2 side windows
all heater unit and controller
center console lid that closes :)
back seats
ash tray (to highest bidder)
fuel flap
fuel tank
2 fuel pumps
still got the front end adjustable tein suspension and stock rear
front right quater panel
front left with verrrrrrrrry slight ding i'll part with it for $100
brake master cylinder and booster
clutch setup
even a complete rb25det 78,000km engine with ecu , loom
ive got HEAPS of lil knick knacks guys but as u see its selling fast so hit me up quick.
Hey man I tried PM'ing you back before but It said your box was full :rofl: anyway, I bought a RB25DET motor complete the other day just missing turbo loom and computer, got it for $600 ;) unreal ay.
Anyway I got another mate that wants to do a twincam RB30, He was going to get a complete RB25DE, I told him to wait around, All he really needs is the head and oil pump, I think he will go aftermarket manifolds, computer etc.
How much did you want for that stuff? Or what did you want for the 25DET motor?
As for the IRS, i should be able to say tomorrow if I will get it or not.
Cheers Edward
Hey man I tried PM'ing you back before but It said your box was full  :cheers: anyway, I bought a RB25DET motor complete the other day just missing turbo loom and computer, got it for $600  :) unreal ay.
Cheers Edward
check ur pm
i mean passengers side front door.
sorry buddy both passenger door and gaurd are sold, got a drivers gaurd tho
and a passenger gaurd with finger print dint in it so slight u could have that for $100 (silver)
I would be interested in R33 S2 front left fog light cover, PM me if u have it. thanks
sorry buddy thts something i dont have, but hey i got bout 2 of everything ese left...haha need anything else?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
