  • Replies 161
whickh one is suitable for an r32 with an rb20det in it?
Hi Roland, the most popular size for an R32 GTS-T is the 600 x 300 x 76mm
Regards,
Steve
hey another question. your piping kits for the r33 gts-t, i have the stock plenum chamber so i just wanted to make sure it was designed the standard position not next to the engine with aftermarket plenum chambers. Also i want to keep a plum back bov on for legal reasons so is the piping suitable for a plum back with an entry point or only atmospheric.
Thanks for your help
The factory cast pipe with the factory bov stays in place with our piping kits. These kits are also designed for use with the factory plenum.
Cheers,
Steve
ow sorry and to add to that atm ive still got the stock exhaust manifold and low mount stock turbo. Will the piping be suitable and when it comes to upgrade will i need to buy new piping to fit a bigger turbo or top mount
You may need to change piping if you fit a large high mount turbo, but if you simply fit a larger turbo in the factory position there shouldnt be any problem
Steve
you just seem to have all the right answers lol. i like that
All pm and email enquiries now replied to
We have another 1000 coming shortly.
Cheers,
Steve
Hi mate, thanks for your enquiry
We have plenty of stock still available
You can place your order online at the URL below:
http://www.justjap.com/forumcoolerspecial.htm
Cheers,
Steve
hey i was just wondering how long they usually take to get to W.A?
Hi Massey, we normally say allow 3-4 business days for delivery to WA.
Cheers,
Steve
Another question. I am interested in the medium size cooler for my R33, however i would like you to confirm that the piping kit would be suited to the smaller cooler.Is there a compatible piping kit for the smaller cooler?
Thanks
Peter
Thanks
Peter
Hi Peter, the 600mm intercooler is the best size for an R33 GTS-T as as such the piping kits are designed for use with the 600 x 300 x 76mm intercoolers.
Regards,
Steve
hey there...i just placed my order for the 600*76*300 cooler to 2774...thanks ;))
Thanks for your order Chris :)
Your order has been confirmed and your payment received. Your cooler will be sent out tommorrow
Cheers,
Steve
Hi Richo, thanks for your order. Your payment has been received and confirmed and your intercooler will be sent out shortly.
Regards,
Steve
I want to fit one of these intercoolers to the front of my 4.2 diesel Nissan Patrol. I think that the bigger IC would suit best but need to make sure that it will fit.
I assume that the dimensions listed are for the core only. Could you please post the overall measurements including the end tanks for the medium and large JustJap coolers?
Thanks in advance!
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
