Hi guys, just been trying to find the best computer parts(new) store in Canberra. I am moving to canberra in sept but want to do some things to my computer and the only one i found so far is very expensive. eg. Epson RX510 3 in 1 photo printer is $485 at one store and the local Umart.com.au in brisi has it for $320.
any tips
Stephen
p.s. anyone interested in a GTS4 in the ACT, check out the forsale section.
https://www.sau.com.au/forums/topic/82453-computer-shops-in-canberra/
There aren't any in Canberra that are reasonably priced compared to many of the bigger interstate stores. You are better off buying online and getting it sent to you or purchasing at the regular computer fairs, although you have to be careful there.
I went to a place in the Churches Centre in Belconnen and when they told me the price I just told them the price I was going to pay and they accepted.  It pays to know your prices.
Very true most will say a set price on the website however generally if you can prove a competitor even interstate they will match it or at least give you a little bit of room to move on the price
Harris Technology in Fyshwick is very good. From my experience, they stock the gear that other mainstream stores (like Harvey Norman etc) don't yet have. Their website is www.ht.com.au and prices are better than most.
I work in the IT industry and agree that it pays to know your price and shop around. Most of the computer stores in canberra want your business and are happy to negotiate. Unlike alot of other IT people, I've tended to stay away from the computer markets. It's luck as to whether or not you may end up with some dodgy stuff and it's not worth it for the sake of a few bucks. And as mentioned, it's easy to visit a mainstream retailer and negotiate a price. The obvious bonus there is that you how to find the store again and can get a replacement or refund if the product fails.
Harris Tech are pretty good (I use them at work) but I personally think they're only worth it if you can get a discount someho., I've seen cheaper places around.
Their customer service is fairly reasonable for a shop (I guess the very large corporate sales they do has something to do with that)
I have been in the ACT for a few months now and I must admit I have not found a computer store I’m happy with. Computer Fairs are very popular here and probably the reason its hard to find a real computer store. Most Sat and Sun you will find a fair on somewhere (check local media).
In Melbs or WA its not uncommon to find stores where you purchase through the front counter, then collect your goods from some massive where house out the back. Something I am yet to find in Canberra (help wanted).
HT in Fyshwick carries a range of stuff in stock. It’s pretty basic and pricy. Harvey Norman and Domain have big computer / technology sections. Stay away from HiMicro in Fyshwick tho. They have all but one blank CD in stock (let alone pc parts) and will charge you for the privilege of listening to them dribble rubbish.
My number 1 for PC stuff nowadays is EBay. If you do your research (like any good purchase) you can make some real savings. To be honest I very rarely use anything else. I try to choose Sydney based vendors for expensive (warranty) type stuff and international for everything else. I could go on for hours about the savings. Time and time again I have browsed the retail stores, playing them off against each other for a lower price. Then I check eBay and find the same item $50 cheaper - delivered to your door.
ive worked for at least half the computer stores in canberra take my advice do not by anything proprietary e.g. hp, packard bell, or anything you would normaly by from a store like harvey norman. get somthing custome. for price i do recomend the computer fair but you have to know what your doing, research your items and the retail price then compair, and try to find stalls that are run by peolple who have there own computer buisness in canberra, many stalls at the fair are mainly asians who run buissneses in sydney who I whouldnt trust them as far as i could throw them. also i pays to go to the fair for a few weeks befor you buy anything that way you can get to know who are the regulers, so you know who will be there if you have to take something back e.g. the fault part they sold you
hop this is of some help
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
