I need a car thats normal family car or something not too powerfull.
1987 VL Calais Turbo, 130,xxxkms, RWC, platnum gold driven,sometimes on weekends. Rebuilt 10,000kms ago by (PET MOD-(03) 9464-4225 more details)
-Fully manualised Trimatic
-3800 stall
-stage 3 shift kit
-B&M(Q.S) shifter
-cooler
-Freshly rebuilt trans.by PROMATICS
-New lsd diff centre with billet axles
intake manifold fully ported and pollished
fully modified cyl head as much as i can do to it cost 2,500
strengthened bottom end cost 4000
garrett external wastegate strait to atmosphere
Screamer pipe, garrett T04 turbo
race camshaft, xf throttle body
Full 3"inch exhaust system from turbo
AVO Stage 2 FMIC with 3'' piping
aftermarket injectors, cost $700
Bosch 044 700hp fuel pump, aftermarket intank pump
Microtech LT8 ECU, catchcan, new alternator, rebuilt strenghtend trans... 240rwkw on 13-14 psi, i ran 12.4 on full street trim
1/april, there is a lot more left, i can say without a doubt that it is a verry quick street car and is not to be mistreated on the street, the car with just a set of semis on it will be capable of 11s as is on 13 psi
it should run 10s after a good tune with slicks and surge tank added.
asking 14,500
i f ur intrested PM me, or contact PETmod about whats needed to run 10s
https://www.sau.com.au/forums/topic/82927-highly-moded-vl-turbo/
i went to a mechanic for a check with stock airbox and stock heat shield and he gave it to me for $80,i dont think that police will care much about it, bcoz its a sleeper VL platinum gold, and its a very quick 1,
if i had money now PET would tune it nicely and it should do around 10.5-22-25 psi or C16 tune with more psi, thats what it was built for.
  • 3 weeks later...
new Time:heathcote 11.8@117mph, after fixing exhaust leak, full service, grippy tyres. last time i was losing power coz exhaust wasnt fully on. Its a 1 big sleeper, It launches quickly, Screams the power !!
Edited by josip
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
