I need to upgrade the wiring to my fuel pump so I can run the standard gtr pump @ close to 14v
Does anyone have any detailed pictures of how to do it?
I understand i need to put in new wiring + relay and fuse and have this connected direct to the fuel pump
Does this mean i need to physically remove the fuel pump and connect the new wiring direct to the pump itself, and put a hole through the grommet and all the other stuff ? Do i need to cut one of the wires leading into the nissan typical 5 plug and connect it to the relay
I would really appreciate any help, because i need to get this done by tuesday
Cheers
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/
Guest two.06l
Cheers
Tommyk....ring me and ill step you through it mate....02 49847847
Paul
DIRTgarage
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1504292
Measure the voltage at the fuel pump before you bother.
The OEM fuel pump relay is in the boot near the battery. There is less than 1m cable between the fuel pump and the battery.
The voltage drop over that length should be negligible...I'll explain why.
Assume the OEM cable has a cross sectional area of 1mm squared (it's actually much thicker)
Assume 1m cable
Assume resistivity of copper is 0.0000000168nΩm at room temp
Now, resistance of the 1m cable = resistivity x length / area
= 0.0000000168nΩm x 1m / (1/1000000)m
= 0.0168Ω
Now, voltage drop is given by current x resistance
Assume the fuel pump draws 10A (should be a bit less)
Voltage drop = 10 x 0.0168 = 0.168V
Which is next to nothing
Soemone please correct me if I'm made any errors
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506869
Thats correct Mik, however the high low resistor is what causes the fuel pump not to receive the full volts when under load.
Unsure why that is my understanding.
Running a dedicated power feed does indeed help.
I'll be grabbing the multimeter and checking mine out. I run an external and internal pump, both of those running flat stick must be drawing quite a few amps, hence my reason to upgrade the wiring to a minimum of 30amp stuff.
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506874
I have run dedicated 30 amp wiring with a 20 amp fuse for my external pump (044). A relay is triggered off the factory power feed to the intank pump. The intank pump (walbro) is still running off the factory wiring through the stock 10amp fuse with no problems.
I also run a surge tank with the return line feeding back into the top so the 044 is effectively feeding itself once primed if the walbro cant keep up.
Only problem i have is the PFC doesn't prime the pump long enough for the 044 to build up rail pressure so i have to turn the car to reds, then off, then back on before cranking.
https://www.sau.com.au/forums/topic/83118-fuel-pump-relay/#findComment-1506992
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
