My 1994 R33 Gtst Series 1 Mspec has to go.
Details
Black
8/1994 R33 Gtst Series 1 Mspec
Same owner for past 3 years
Serviced every 5000k
Is coming up to 160 000 genuine k's (bought it at 100 000k's in Aug 02)
6 Months rego just paid (due April 06)
New battery Nov 04
Just had 155000k service incl fuel filter
Timing belt and water pump were changed at 100k
Air-con compressor changed and re-gassed june 05
Majority of k's were done between Perth and Bunbury
Performance Engine Mods
Recently ran 268 rwhp @ 10psi (in shootout dyno sheet to show)
Front mount cooler
Turbo back 3" with tuned length dump pipe/front pipe combo
Trust Type S Bov
Pod filter
AVCR
Remot oil fiter kit
Remote engine oil cooler
Engine Grounding kit
Hi speed starter motor
Drive train mods
brass button/ceramic clutch (new april 05)
C's solid short shifter (new feb 05)
Rear cradle bushes (pineapples)
Tomei Hicas lock kit
Suspension
Kei Office adjustable coil-overs (fitted this month)
Cusco castor rods (o/hauled and fitted jan 05)
Front strut brace
Brakes
Custom slotted front rotors
New ferodo formula pads (july 05)
Body
MFX Tyrant front bar (new dec 04)
Type m side skirts and rear spats
Aluminium T wing (original wing removed and hole filled professionally)
GTR Grille
Cusco style radiator air guide
Cutsomised front indicator/parklights
Rear "skyline" light up garnish (new jan 05)
Customised rear number plate neon
Chrome graphics (brand names)
Tinted rear windows
AMG Eclipse 17" "argon" wheels (chrome) (new Nov 02)
Full NEW set of 235/45/17 tyres
Interior
Trust Dual pillar pod (new june 05)
Sard El boost guage (new july 04)
Pivot Intake Temp guage SGIT (new july 04)
Apexi pen-type turbo timer ( new jan 04)
Apexi RSM with G sensor
Autotechnica steering wheel with hicas boss
C's shift knob (came with short shift)
Standard Skyline floor mats
4 point harnessess
Neon fitted to glove box
Stereo
I am selling without deck/amp/sub
Will sell with Kenwood 6 1/2" splits in front
Asking $21 000 ono
Number plates NOT included
This car comes with mod permit for guages, intercooler and exhaust.
It is in almost perfect condition and has never given me any trouble since buying it.
I have done most of the mods myself (i'm a mechanic) and had it dyno'd by professionals.
Has just passed pits for permit issue
Email me for pics (i have plenty)
[email protected]
Or call 0409117081 if interested for viewing
Edited by CMS Drifter
https://www.sau.com.au/forums/topic/84134-1994-r33-gtst-s1-perth/
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
