Item:
Compaq Evo N1000c Notebook
Intel Pentium 4-M 1.7ghz - 256MB RAM
ATI RADEON 7500 Mobility
15" TFT - 1024x768
30GB HDD
DVDROM
Windows XP Pro
Brisbane
Item Condition:
In pretty good condition, mainly used as a desktop replacement, display is perfect, no dead pixels, battery still holds pretty good charge. some slight scuff marks from watch band.
Reason for Selling:
Upgrading to new powerbook.
Price and Payment Conditions:
$500 ONO.
Contact Details:
email or pm.
Edited by ph1
https://www.sau.com.au/forums/topic/84215-compaq-evo-n1000c-notebook/
