Just a quick question, has anyone used or had experience with the Supra cores on a Skyline. Im referring to the 7M-GTE version with the outlets on the same side. Handy for RB20 owners with both pipes on the same side :P
It seems to me like theyd be a pretty good size for an RB20DET, however ive heard about them being generally inefficent. I believe the measurements are about 500 x 280 x 75.
In terms of scope of development of my engine, im really only looking to run 0.8-0.9 bar safely... which at the moment is proving dangerous on the stock core (already broke 2 exhaust valves due to detonation and lunching a spark plug).
The future may hold an RB25DET, so im not too fussed about spending heaps on the 20.
Red17
https://www.sau.com.au/forums/topic/8509-supra-cores/
should be fine but I dont think your cooler is the problem
check your timing it should be at 15 degrees or even the type for fuel you use shouuld be 98 not plp which is 95
your car might have an after market ecu tuned for high rom fuel or your fuel pump could be on the way out I would look at these area's
meggala
https://www.sau.com.au/forums/topic/8509-supra-cores/#findComment-123860
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
