To tell you the truth, i dont know what i want to do turbowise.
I do however plan to buy a brand new turbine, unless i find a good 2nd hand bargain. I was thinking something along the lines of a GTRS or maybe 3037S.
But again, i am not too sure, and this wont be something i will be buying for ~6 months, so i dont really want to say anything...but yes, a GTRS = good turbine
(i hate std turbine, too responsive for my liking)
  • Replies 43
