  • Replies 67
Posted Images
I call it ON
Tonight and Saturday
A clearing shower or two tonight. A fine, partly cloudy day with moderate north
to northwesterly winds.
I will be there, regardless... :cheers:
Noon, Jells park, 2nd carpark...Look for mine or Ians car (Big white stagea or big blue stagea)
Get a quote from Zac first, but i find when i buy something the size of a turbo timer for ~13000Y+3000fee+1500inland postage/japanese bank fees+2000Y postage to me = 240AUD landed...
To me, it aint worth it... but it is a set, meaning like, clear side AND front ones...i dont think thats much help when ill be getting a new 260rs/DAYZ front bar though...
