Hi Guys,
I know I have been a bit dead lately, but that goes with when you get told you have a malignant cyst on your large intestine.
Anyhow, ALL my hot bits are up for grabs, as the PNV is staying as an L series quickie.
If your interesed get in touch.
Dennis
https://www.sau.com.au/forums/topic/85567-hot-bits/
what have ya got ?
All the bits I have have been well documented on these forum pages.
I was planning an RB30/25DET conversion so everything is pertaining to that.
Trust inlet plenum NEW complete, HKS ext wastegate cast iron exhaust manifold, HKS 40mm ext wastegate 10psi spring, a/mkt 40mm ext wastegate 14psi spring, RB25DE DOHC head complete, R33 GTS25t gearbox, R32 RB20DET gearbox, NISMO short shifter, NEW RB30E harmonic balancer, 1.0mm o/size ACL Race Pistons suit RB25DET (forged), RB25 bottom end, RB30 GTS1 bottom end, R32 245rwkw ECU incl loom, Billet Steel flywheel that will accept 10 in VL Turbo clutch, NEW VL Turbo clutch plate, N1 Oil Pump & Adaptor, VL Turbo Oil Pump, GTR Speedo drive, NEW GTR valve springs, Gates timing belt for RB30 DOHC conversion, RB25 throttle body, 2 x Z32 AFM's, and more.
https://www.sau.com.au/forums/topic/85567-hot-bits/#findComment-1549117
how much for the lot of the rb30/25 conv setup?
https://www.sau.com.au/forums/topic/85567-hot-bits/#findComment-1549712
The whole conversion???????
RB30E Block, crank, rods, caps etc
RB25DE DOHC 24V Head
GTR Valve Springs
Timing Belt
Tensioner Pulley from RB25DE block
1.0mm o/size ACL Forged Race Pistons
N1 Oil Pump and adaptor or VL Turbo Oil Pump
Standard Inlet Plenum & Runners or Trust Inlet Plenum
R33 GTS25t 5 speed Gearbox or R32 RB20DET 5 speed Gearbox
RB30E Harmonic Balancer
RB25DE Throttle Body
Z32 AFM
RB30ET Billet Steel Flywheel
VL Turbo Clutch Pressure Plate
That's probably about it.
Tell me how much of this conversion you want and I will price it up.
Cheers,
Dennis
https://www.sau.com.au/forums/topic/85567-hot-bits/#findComment-1550178
GTR Valve Springs
Timing Belt
VL Turbo Oil Pump
R3 GTSt 5 speed Gearbox
Z32 AFM
VL Turbo Clutch Pressure Plate......price for above and price for no clutch/flywheel/gearbox
https://www.sau.com.au/forums/topic/85567-hot-bits/#findComment-1550937
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
