I put my Ball & Spring Boost Controller on today and at first it was on like full boost. Went right upto 14psi. It sounded insane and it felt soooo much faster conpared to the 6 i was used to. Turned it down to around 11psi but the boost holds really weird and my auto wouldnt change out of 2nd. It kept kinda spiking and fluttering away on my boost gauge.
Now my TCC Work BOV that I put on a week ago finally makes some noise as my boost it up. But it sounds bad...like a SSQ BOV and a Monza put together....
The crack in my radiator also grew around 15 cms and practically all my coolant escaped...I got some Selleys ARALDITE Super Strength to try to seal the crack but i wasnt successfull the first time as I got impatient after 6 horus and started the car to see if it would seal but it just blew holes through it, so im trying again overnight and hopefully it holds tomorrow.
I'm getting a new Aluminuim top tank made up and put on for my radiator on monday so that should be good.
https://www.sau.com.au/forums/topic/86376-boost-controller-is-on/
Took my Ebay Ball & Spring controller off as it doesnt seem safe to me.
I got a GFB Atomic boost controller http://www.gofastbits.com.au/index.php?par...b_option=atomic to go on once my radiator is back.
These are probably a stupid questions but...
Can anyone give a straight answer about getting your engine re-tuned once a boost controller is fitted..?
If you don't does this lead to detonation, or leaning out?.. or anything else that may be detrimental?
Also what is a safe boost increase for a stock FJ with 2.5 exhaust and no cooler?... around 8 pound?
Cheers.
:D
Edited by slide247
Cheers.
:D
I'd be putting it on a dyno to make sure its not leaning out etc etc, if thats all good then a retune isnt in order, if it is leaning out a retune is in order...
They already run 7 from factory, so maybe 10????
I've got an atomic boost controller on my HR30 and it seems to be holding boost very well and it's been on for about 10000km's running 11psi before I took it off the road to fix other problems.
Edited by OLD SCHOOL R30
thats reall good to know. when i get my new radiator in and motor back together ill be using a GFB Atomic Boost controller and by the sounds of it since it seems safe ill put it at 11psi :-)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
