People could please make sure that if you do have these rims they are not the 6.5inch wide version. They are stamped 16/7.5 45 offset on one of the inside spokes.
These rims are possibly off the AWD non GTR Skylines not sure. But I have definately got two 7.5inch wide R33 Skyline Rims and I want 2 more.
Or will take 4
https://www.sau.com.au/forums/topic/88781-standard-r33-1675-inch-rims/
  • 3 weeks later...
