i was wondering what everyone else has
Ive goT a
DXZ956MC clarion Head Unit
TS-C160R Fronts speakers and amp pioneer.
TS-D161S rears
GM-6100F speaker amp
SWR-1222D sub im using a low power amp so the 2ohms is much
MRP-M350
https://www.sau.com.au/forums/topic/89253-people-audio-stuff/
Source: Clarion HXD2
Processing: Zapco (SymbiLink)
Amps: Zapco C2K-6.0X's
Front: Rainbow Reference 6.5" midrange, Morel Supremo tweeters and Boston Z ambient tweeters.
Rears: Toyota Soarer 6"
Subs: Diamond Audio TDX12
Cable & Deadening: Streetwires / Stinger.
Batteries: Stinger SPV44 (front) / Optima D34M (rear).
Source: Clarion DRX-9255
Processing: Orion Concept 97.2 (Limited edition DEQ30) completely digital EQ and Phoenix Gold Zeropoint ZPX2 3way Balanced xover
Amps: Phoenix Gold Zeropoint ZPA0.3s
Front: Dynaudio System240mkIIs. soon to have esotars or morel supremos added and the original tweets moved up to ambients.
Rears: no way!!!!!
Subs: Sold my adire audio brahma. still looking for new sub.
Cable & Deadening: Stinger/Van Den Hul/Monster Cable/+custom made stuff
Batteries: Optima D34
and none of its installed!!!!! :unsure:
Edited by djhatton
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
