'Lo Folks, someone's gonna bag a bargain !!
Item: HKS GT2530 Dual BB turbocharger, .64 A/R T25/T28 flange, 5 bolt discharge outlet. Universal style comp. in/out. With some tube bends can be adapted to practically any installation
Item Condition: As new, never fitted, see Extra Info
Reason for Selling: Not required, have a GT2535
Price and Payment Conditions: $1300. Cash, bank deposit, buyer pays postage/courier. Sydney (Parramatta) buyer has priority. I would prefer a buyer to inspect first before committing to purchase.
Extra Info: Remanufactured by GCG april 04, receipt for $795. New CHRA, balanced on a Schenk VSR, brand new turbine housing, never fitted since remanufacturing, assembled & balanced to better than Garrett tolerances. Turbo only, NO ancillaries. What you see in the pics is what you get.
Contact Details: PM, email, or 0410424470. Please be aware I work awkward hours & can't field responses after 12pm & before 12am.
Please ask rather than make any assumptions, I'd like this to be a good kharma experience!
https://www.sau.com.au/forums/topic/89449-hks-gt2530/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
