SYNCHRO-MODE ATTESA E-TS (electronic-torque split) SYSTEM
(Electronic controlled torque split 4WD vehicles)
Depending on the conditions of the road, this system controls the drive force of the front and rear wheels providing an enhanced drive performance. The road and drive conditions are detected by various sensors and the front-rear wheel drive force will constantly change from 0:100 ratio (rear wheel drive) to 50:50 (4WD) depending on the drive conditions.
SYNCRO MODE
By increasing the drive force to the front wheels, the synchro mode provides enhanced acceleration from a standstill and turning performance even on icey roads and in severe conditions.
ADVICE:
When the syncro mode function in turned on, the following phenomenon will occur (These are no abnormalities)
-Tight cornering effect when driving at slow speed.
-Vibration when the engine is turned off with the steering wheel turned completely to the left or right.
SWITCH
OFF - 100% of the force will be on the rear wheels when taking off. When the rear wheels are slipping, transfer the drive force to the front wheels.
ON - The front and rear wheels will share 50% of the drive force each providing stronger take off stability.
Would people agree with this the yellow bit???? Maybe I should start driving with the torque split on more.
Well probably as the front will have the same power as the rears, so logic would dictate that a launch with 4 wheels driving would be better than a launch with 2 wheels driving and then having 4 kick in.
Still that means that you have 4 wheels driving all the time, which I dont know is a good or bad thing?
I have done some playing around with the snow button and she seems to get up and go a lot quicker with it on, dont realy notice anything different when just driving around normally, except for the HICAS light coming on when the snow button is pushed down.
I checked and no I dont have a HICAS unit on the back so I assume that the light is infact showning me that the snow button has been engaged.
Anyone else done any researching on it?
I drove with teh S mode on to uni and back today. For some reason i even notice more midrange in the car, compared to just normal driving. I find it also goes around roundabouts and uturns/courts a lot quicker with less understeer..
Snow mode doesnt adjust power, snow mode just doesnt use first gear.
Snow mode is on the transmission, syncronise is on the dash (S in middle of 4 wheels)
Oddly, Ians manual stagea didnt have teh S button feature, but Ska's manually converted one does...?? Odd ey?
You don't need a 'snow' button when you have the 'gear stick' one.. :)
With most autos (not sure if true with the stagea) all the snow button does is shift where the auto changes gears...
As for it locking in 4 wheel drive, you don't really need that, the stagea gets the power to the front very fast if the back wheels look like slipping, ie if I floor it at the lights in 1st , when I'm on a wet rd, the front torque (remember I have a gauge) cuts in pretty much at once anyway... It's also smart enough on dirt as well..
Ian
When i put mine in snow mode (on the trans), it just starts me in 2nd gear.
Like, i get bogged down launches and so forth.
The sync button is tottally different to snow, it makes certain its full time 50:50, and not variable as normal driving, therefore making it like its got a central transfer case which is permanently geared to run X split
Where is the button which we are all talking about?
Mine is on the left hand side of the steering wheel below the console, I'll take a couple of pics on the weekend :unsure:
All I know that when I hit the snow button it "seems" to take off faster and the HICAS light comes on.....?
So where is this sync button ?
Sync button is LHS of steering wheel, big boxy looking button & a light comes up on the dash, Snow mode is RHS of auto shifter (power, normal, snow), no light on dash but the button turns 'green'.
Edit: correct??
Also, in Snow mode my auto gets switched to 2nd gear, = slower takeoffs. If I want to be beaten at the traffic light grand prix I press snow mode! :lol:
Brendan
Edited by bwilkeson
I was driving on some loose gravel the other day playing around with Synchro off and on.
With it off the car still got sideways fairly easily, and spun the wheels when flooring it from a standstill.
With it on the car spun the wheels noticeably less when taking off and was not as easy to get sideways.
All of this was done with the trans in normal (i.e neither power or snow)
Ok, to clear this stuff up
The sync buton makes an orange/yellow light on the dash come one that looks like this
Snow button: Doesnt use first gear
Sync button: 50:50 split front/rear
My questions,
Why doesnt Ians manual stagea have the 50:50 split? Its more for traction etc, and sure the system is fast enough anyway, but...why?
"A/T Mode switch
Normal: Transmission will automatically change from power to economy mode as the conditions require (eg hill driving). When power is required the power light will appear on the dash.
Power: Gives the engine more power which is useful for hills, faster starts, etc. When the power mode is selected the power light will show on the dash.
Snow: For driving in snowy conditions. Place the select in the D position. The ability to start, drive and stop on slippery roads will be enhanced.
Note: This vehicle is a full-time 4wd.
Tight Cornering Effect: While driving with the Synchro mode in the ON position and the steering wheel is fully turned (to either side), the vehcile may brake suddenly. This is called the tight cornering effect and is the result of the difference in rotation speed between the front and rear wheels when the vehicle is turning. This is not a fault. The steering wheel will seem heavier to turn."
Synchro-mode: see first post
From the translated manual. I have no lights as such on the dash, but the switch itself lights up.(edited)
Q: Ian, is your car 4wd or 2wd?
Edited by bwilkeson
Surely you jest :) 4wd of course (It's a 25t RS FOUR S) ie http://english.auto.vl.ru/catalog/21830/
But remember I have a LSD, which might be helping me a lot - with previous cars I've noticed an enormous difference on dirt with or without a LSD..
I have a front torque gauge so can tell how much (and when) is going to the front. Even on loose dirt I don't have trouble with power going to the front instantly when needed, so don't feel any need for a switch to go 50:50… :) Which is probably why they didn't put one...
Sorry Ian, just asking, although I was hoping I wouldnt hit a nerve with the query. There seem to be so many variances within the same model of car....... :P
Well mines a manual convert with the 260 dash, which is prolly why I have that Sync switch.
I dunno if having a GTR diff makes any difference yet, I am yet to take it to a nice grassy patch for some "extra curricular" activites :)
Ska, what driveline parts have been changed in your car, doing the conversion myself right now, i will be swapping the diff with a NISMO item later when i can afford it...
Honetly I couldnt tell you excatly.....? PM Gary1 or contact Mercury Motorsports, details posted in your other thread.
found a pic of the button:
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
