Orange Grove Maccas?
Guest Diabolik1
Hey people,
Just to ask a little question.
Does anyone meet up there anymore?
Nearly every fri, sat and sun im going past there at around 11-3am, (depending on what i was doing that night) and theres never that many cars anymore.
I remember going past ones and seeing literally at least a hundred cars...have they now bloced access to the Mega Centa parking?
Also, if any of you people do meet up there, what time? cos i wouldnt mind stopping by meeting a couple of you's and seeing some sweet cars.
And another thing. Do the cops ever block that street off so no one can get out and start defecting? (a friend told me, and i dont know if its true)
ANyway, hope to see some of you there or at another location or cruise. Safe Driving
Goz
https://www.sau.com.au/forums/topic/9104-orange-grove-maccas/
Guest Allan GTI-R
Originally posted by DR GTR
Allan you are welcome to meet up with us again this sat night at 8pm at BK.
Bring the vaseline ok. I want to introduce you to sum of the boys :D
actually i remember you at Appin.
who owns the gti-r with the Asian guy in it - that thing is damn fast :lol:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
