umm I'm still new with car stuff...can sumone explain what's gear ratio for? as simple as possible...
also why do ppl want to get HICAS lock bar? aren't those the stuff which locks up the diff? so when taking corners locks up and both inner and outer wheels turn at the same speed...wouldn't that cause bunny hop?
the bosch fuel pump 040 and 044 the differnce must be the capacity to pump but anyone know what are they, I'm looking to get an aftermarket fuel pump but dunno how to choose, what to look out for?
https://www.sau.com.au/forums/topic/91366-hicas-lock-bar/
Read up on this page;
http://science.howstuffworks.com/gear-ratio.htm
I know it's "geeky" but this site will pretty much cover the basics of how parts in cars work. This explains how gear ratio's work.
When talking about gear ratio's on cars, it refers to the transmission or the differential.
HICAS lock bar is to simply remove the HICAS system on Nissan cars equiped with it. In simple terms, the HICAS is a computer/hydrolic system which makes corrections to the cars rear wheel above 80km/h in a given corner. It has nothing to do with the diff.
For the average driver it works a miracle. But for someone who's looking for complete control of the car, it's not pleasent. The computer is correcting the driver, while the driver is correcting the computer so it's a never ending battle.
https://www.sau.com.au/forums/topic/91366-hicas-lock-bar/#findComment-1645663
And through fast corners (90km/h and over) it feels as if they tyre has rolled onto its sidewall when u turn in, and it feels like you have driven over a slippery patch of road
If you follow a hicas equipped car u can actually see it unsettle the car, a friend described my car as looking like it had driven over a patch of sand whenever turned into high speed sweepers...
it really detracts from a good drive it puts me off heaps. i dont see how it could help anyone! i need a hicas lock bar..
https://www.sau.com.au/forums/topic/91366-hicas-lock-bar/#findComment-1646016
As "Silver-Arrowz" and "siksII" have said just stops HICAS ruining your fun, and feeling a bit dodgy at high speed cornering by disabling the rear wheels from assisting in turning the vehicle. But I read my mates new HPI mag today, they fully explain a lot on GTR's as it's a "GTR special issue" and a good read for those who havent seen it yet... :angry: yes explains HICAS lock bars and more
Cheers
Edited by WhatBrake
https://www.sau.com.au/forums/topic/91366-hicas-lock-bar/#findComment-1647870
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
