Light weight wheels reduce the unsprung weight of the car. This reduces the amount of effort required by your suspension to control its movement, and so your suspension can spend more time doing what its meant to (i.e. absorbing bumps).
An important concept is "unsprung weight." This is weight that is not supported by the suspension of the car. This usually includes the the weight of the wheels and tires as well as a percentage of the weight of the suspension itself, including control arms, anti-roll bars, shocks, and struts. Reducing unsprung weight is the key to improving handling. The lower the unsprung weight, the less work the shocks and springs have to do to keep the tires in contact with the road over bumpy surfaces.
Source: Muscle Car Club
Alternatively, you could run larger diameter and/or wider wheels. This reduces your tyre's sidewall height and increase the car's track, for better handling, while not increasing your unsprung weight and decreasing your suspension's effectiveness.
Lighter wheels also reduce your rotational inertia, which should bring gains to acceleration (in a similar fashion to reducing the weight of other driveline items, such as your flywheel).
From what I understand, reducing the unsprung weight has a much greater effect (per unit reduction) than reducing sprung weight in terms of handling. Same with reducing rotational inertia from the driveline.
i.e. pulling 10kg out of the wheels will do a lot more for handling and the car's acceleration than, say, ripping out 10kg worth of interior trim.
I could be wrong on this last point though.
Edited by scathing
What car have you got, and have you considered what rims you're getting? Have you considered what tyres you're getting as well?
If you're going to get a very sporty (or Comp-R) tyre, they tend to have reinforced sidewalls. As such, going for a larger diameter may not necessarily bring you handling improvements over a smaller diameter with good tyres. Generally tyre weighs less than metal, so keeping a smaller diameter wheel with good tyres might "handle" just as well, but with the benefit of having a lower unsprung weight.
Lower profile tyres inherently have reinforced sidewalls (since they can't be permitted to flex as much), and since high profile street tyres generally go on econoboxes designed for people who want asoft ride, you don't get as high a percentage of what's available with good sidewalls.
If you're going for a proper semi slick, however, your need for a big rim with low profile rubber isn't as pressing. I ran Falken Azenis RS-V04 semi slicks on 17" rims for a while. They felt stiffer than the Bridgestone Potenza RE040 street tyres I had on 18" rims (in terms of the steering response and feedback when cornering on smooth road / track), but with the lower unsprung weight the car's ride comfort and bump absorption was better on Sydney roads when using the semis.
Its also a lot cheaper to go for a smaller tyre, which is definitely a concern to me with the rate at which I chew through them....
Edited by scathing
Ive got 15x7 on at the moment.
Looking to get either 17 or 18 ( but mostly 18s) and
8 or 8.5 inches wide.
I looking at mainly Jap lightweight racing wheels
like ray volk, work, etc.
I dont want to go lower than 40 profiles for my tires,
because I was told that any lower you will fill the bumps
in the road more.
OK, if your stock rim is 7" wide then you can run an extra inch without getting an engineer's cert.
On an 8" wide rim you can go anywhere from 215-255 width. I'd probably opt for a 225 or 235, just because those widths are easy to find rubber in.
You could run a 245/35 R17 tyre, and its rolling diameter would only be 0.5% off. On a 235 width you'd have to run 235/45 R17 and you'd be 1% off.
Go up to 18" and you'd be looking at a 215/35 tyre and you'd be 0.1% from factory.
(Recommended widths for an 8" rim thanks to Falken Tires. Calculations courtesy of Miata.net's tyre calculator.
Doing the numbers, if you want to keep it over a 45 profile without having to do a speedo /diff recalibration you're going to have to stick with 16" rims. That's assuming you want the tyres as wide as possible. You could stick with 7" wide rims, run narrower rubber (for example a 195/45 R17 tyre will have the same rolling diameter as your stockers) and get your profile back.
Mind you, the actual sidewall height difference between a 245/35 R17 tyre and a 195/45 R17 rim is only 2mm, so in terms of how much sidewall you've got to absorb bumps there's nothing in it.
I haven't tested it myself to see if an 88mm high sidewall on a 195mm wide tyre will absorb bumps significantly better than an 86mm high sidewall on a 245mm wide tyre, but I can't see there being much in it. Nor do I know if having a 55mm wider tyre (and so a 55mm wider track) gives you better handling either, but it seems likely that it will be noticable.
What I do know is that the lower profile tyre will cost a lot more, so that's something else you should consider. If you're serious about replacing your wheel / tyre combination for performance then you're not going to scrimp on tyres, so you need to work out what you can afford and buy rims to suit.
There's no point having LM GT4 Magnesium wheels if you can only afford to put retreads on them.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
