ill get back to ya with a time when im free mark, im a little busy this week but nothing that cant be sorted out ;)
Yeah I was thinking some nice freeway shots for you???
Should only take half an hour or so ;)
  • Replies 139
Posted Images
Sorry Mick, fu<king whacked out day.
I'll let you know.
I did get MRR34 done, thats one down 11 to go.
I heard nothing last night??? (Just as well really, House 2hr special was on)
Weekend maybe???
ok i think to make it easier i might just miss out.
a couple of reasons. i now have stickers on the car so wont look as good for the calendar.
and im racing at the Powercruise StreetCar Shootout on Sat 6am-10pm
:D
and i know how hard it is for you to get everything together, so its okay.
mick
i'm available Friday night, from about 7:30 onwards, Saturday morning up until about 12, and Sunday afternoon after 4:30...
When would you like me, Mud?
(Car is covered in dirt/bugs/etc at the moment, so i gotta know when to wash it :P... already cleaned the engine bay though, so thats all good)
Done and Done.
see you at 4:15 at Shell Nudgee is fine
7:00 if its raining, but I doubt it will.
You still good for this Mud, I certainly am, 4:15am god damn that means up at 3:45am to get there :)
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
